Jul 19th, 2024, 7:20am
Pages: 1 2
Biasing circuit for telescopic amplifier (Read 5044 times)
steven
Jan 18th, 2006, 10:12pm
I have a question on biasing circuit for telescopic amp. Hope I can get some references and comments on my doubts. Taking a conventional telescopic amplifier, ie., the half circuit contains 2 PMOS and 2 NMOS, the bottom has a current source NMOS at the common gate of the two paths, there are 4 biasing voltages. These voltages are for the top PMOS pair, second PMOS pair, stacked NMOS pair, and the bottom NMOS. Also assuming that these biasing voltages can use idea voltage sources, that is, no using biasing networks. Given these freedom, what is the best way to design these voltages? Further assume the biasing voltages set all input/output common mode voltages at the middle of their ranges.
I was thinking like this: since the key is to make the transistors at saturation, so with Vdssat=0.2 for all devices I should be able to set the biasing voltages. However, it seems that it is not as easy as I thought since some transistors will be easily out of saturation if a little change in the input common mode voltage or some variation in mismatching. Am I thinking this problem in a wrong way? I mean the biasing circuit should be dynamic rather than making the above fixed biasing voltages assumption.
Anyhow, references are well appreciated.
uncle_ezra
Re: Biasing circuit for telescopic amplifier
Reply #1 - Jan 19th, 2006, 1:19am
Why don't you want to have a biasing network? I highly recommend you design a biasing network so that it will make your life easier. A biasing network will help track process, voltage and temperature variation and hence change the voltage bias accordingly. Also is the architecture differential or single-ended? If differential you need a CMFB network.
Hope this helps!
steven
Reply #2 - Jan 19th, 2006, 9:08am
Hi Ezra,
Maybe I didn't express my point well: in design, we always can set the overdrive voltage or Vgs by biasing current and transistor size. However, Vds is controlled by factors external to the transistor, which needs some thoughts in picking the drain voltage Vd(assume the source voltage Vs has been set by the condition Vgs>Vth). Even though Vds>Vov=Vgs-Vth is met, I think there are still many options can be done and also changing Vd sometimes will change the transistor state too. In the telescopic amplifier example, excluding the biasing circuit, I was thinking a best way to bias the stacked transistors using independant voltage sources. That was my question.
Yes, I know biasing circuit is easier and I have found some references later on. But I want to check if my thoughts are wrong or not.
Thanks.
Croaker
Reply #3 - Jan 25th, 2006, 2:44pm
Hi Steven, the fact is that Vds will change as circuit voltages wiggle.  That's why there's an ICMR for an op-amp.  You basically just set Vgs to give you the right overdrive voltage AND you may have to use more gate voltage to make sure Vds is far enough away from Vds(sat).  Short-channel devices don't have an easy to define Vds(sat) so you basically have to decide where to bias Vds based on the desired amount of output resistance.
Does that answer your question?  I think you know what you are talking about but you just had some doubts about the design philosophy.
steven
Reply #4 - Jan 25th, 2006, 10:38pm
Hi Marc,
Thanks for your comments. I understand what you said, however, I don't quite understand what is going on in this circuit. For exmaple, in the attached figure, bias voltages have been labeled. I didn't draw the bias network and CMFB network. Vb1 and Vb2 are from the bias network. Vbias comes from CMFB. As can see from M1 to M4, the bias is not right, ie. Vds are too small than Vds(sat). I tried to achieve the big "AND" in your post but no avail so far. Something is wrong.
Steven
Cri Azzolini
University of Parma, Italy
Reply #5 - Jan 27th, 2006, 12:36am
Hi Steven,
regarding your telescopic OTA, the source voltage of M1/M2 is defined by the input-common mode of the opamp and by the ratio Id1 / (W/L)1: in my opinion you should try to properly bias the M1/M2 since the CMFB loop will work fine only if the opamp's tail device is out of triode region (it seems to me that your CMFB is not working at all if the output common mode is 0.104V!!). You may want to enlarge your differential pair or raise the input common mode.
As a second matter, the voltage at the drain of M1/M2 is defined by the gate voltage of M3/M4 and by their size: again, you should enlarge M3/M4 since, in my opionion, a gate-to-source voltage equals to 2.45 is too high for M3/M4. The biasing of M3/M4 and M7/M8 is quite delicate for they should be properly saturated event when the opamp's output voltage is completely unbalanced (full swing condition): generally speaking, the telescopic architecture is suitable for medium-low output swing: if you require more swing (1.5V-2 V) you may design a replica-tail feedback loop (quite complicated for high-speed applications!) or change your topology toward a folded-cascode (more power-hungry!).
In order to find the appropriate biasing and size of M3/M4 you can also substitute MB5 with a voltage source and, once all is fixed, come back to MB5. That is a standard routine during the first design activities.  ;)
Bye,
Cri
View Profile WWW cri.azzolini   IP Logged
Croaker
Reply #6 - Jan 27th, 2006, 7:40pm
steven wrote on Jan 25th, 2006, 10:38pm:
Hi Marc,
Steven
One nasty problem is that Vsd7 is far too big...it eats up all your voltage.
I'd say you haven't sized the transistors to handle the current sourced by M5, Mb4, and M6.  I would need to know the branch currents and transistor sizes to make any useful comments.  You'll also need to size Mb5 so that it has Vds5 > Vgs + Vds(sat).
Make sure vbias MOS is 3x to handle all branch currents.
Mb5 should be sized to give the targeted Vgs + Vds across it when you run the branch current through.
Other sizing tips: pick the gm you want, and vgs you want.  size each transistor type so that it gives you the desired gm at the vgs you selected.  do a vgs sweep with vds set to the target vds when you are trying to get gm
What Vgsn, Vsgp, Vdsn(sat), and Vsdp(sat) are you targeting?
What is Vth for each MOS?
What is v+, v- at?
steven
Reply #7 - Jan 27th, 2006, 9:01pm
Marc Murphy wrote on Jan 27th, 2006, 7:40pm:
Hi Marc,
Steven
What is v+, v- at?
Hi Cri and Marc,
Thanks for both of you commenting on the circuit. As Marc said, I didn't size it correctly when I posted but tried to illustrate how to get around the Vsd7. I can size them to have open-loop gain at around 85dB but GBW is too small. Still I don't feel comfortable on something. Here are the parameters I used:
V+ and V- are at 1.5.
Vthn is 0.6, Vthp is -0.8. I tried to set |Vds(sat)| around 0.2. Actual Vds(sat) is about 0.3~0.4 (absolute value). Vds(Mb5) now is about 1.2V. It was really hard to set Vds(Mb5)=Vgs+Vds(sat) (I am happy to listen your tricks on doing this).
M10 is in trio mode though, Vds10=0.04 < Vds10(sat)=0.9. I don't if I still need to adjust it or not. The others are at Saturation.
Half branch current is 3.3mA, Id(Mb5) is 31uA. Maybe I should redraw the circuit to show the sizes. Before that, I want to ask these to Marc,
1. When you said make sure vbias MOS is 3x, what is the 3x compared to?
2. How do you do a vgs sweep? This is very useful since I didn't know how to set M3 and M4 efficiently before I posted the original post.
Steven
Croaker
Reply #8 - Jan 28th, 2006, 3:43am
I will answer your questions in more depth later...gotta go to a seminar!  There is a simple, systematic way to handle things.
3x is in relation to the other NMOS.
Just take a single MOSFET.  Hook up a voltage source to the gate and another to the drain.  I don't know what tool you are using but they all can do a DC-sweep of voltage.  Just sweep Vgs.
If you didn't know how to set M3 and M4 than the rest of them are probably off too!
Try the sizing tip I gave and that is where you need to start.
Gotta run!
steven
Reply #9 - Jan 28th, 2006, 11:16am
Marc Murphy wrote on Jan 28th, 2006, 3:43am:
Just a quick reply. Here I guess (really guessing) we had a misunderstanding of each other:
When you said "Vgs sweeping", you meant that connecting a *single* transistor and do a DC sweep to find correct Id and (W/L), right? (But hand calculation is quite close if I check with this sweeping setting up). If this is the case, I believe I asked a wrong question. I was thinking you were referring to Cri's comment, ie., fixing some voltage source then sweeping the other to find the appropriate Id and (W/L) while keeping the *whole* OTA topology. If this is not what meant, I need more comments from you.
Steven
Croaker
Reply #10 - Jan 28th, 2006, 12:59pm
steven wrote on Jan 28th, 2006, 11:16am:
Steven
I wasn't referring to Cri's comment, although now that I look at it, he is also concerned with the odd voltage drops and probable sizing problems.  I was basically saying you need to properly size your transistors for the vgs and gm that you want.  You can figure out the right size for your basic transistor NMOS, PMOS by using a single transistor.  There isn't a need to change the OTA topology.
Croaker
Reply #11 - Jan 28th, 2006, 1:27pm
Let's say we want Vov=Vgs-Vth=0.1*Vdd=300 mV
So, Vgsn=Vthn+0.3=0.8 V
Vsgp=Vthp+0.3=1.1 V
sounds like Vds should be around 0.3 V for saturation
pick fT, which leads to your gm
do the vgs single tran sweep to find out what size gives you the right gm at your desired vgs (vds is set to around or more than vds(sat))
now you know the sizes for all NMOS and PMOS in your circuit.  M1, M2, M3, M4 are going to be the same size.  All PMOS are the same size.  I think the thing that may have messed you up is that the PMOS were not sized right relative to the NMOS.  The KEY to making the rest of the circuit work is the proper sizing of MOSFETs and now you have almost all of the sized to sink the right current at the chosen bias voltages.
Each PMOS branch will have roughly the same current when in saturation.  You size M10 to take all the current, so it is 3x bigger than the other NMOS.  You make Mb5 smaller to raise its voltage to at least vgs+vds, to keep M3 & M1 happy.
steven wrote on Jan 27th, 2006, 9:01pm:
Hi Cri and Marc,
Steven
steven
Reply #12 - Jan 28th, 2006, 9:36pm
Marc Murphy wrote on Jan 28th, 2006, 1:27pm:
Vsgp=Vthp+0.3=1.1 V
Hi Marc,
Thanks for your quick clarification. I know what you mean now. The way you pick gm is new to me. I used Id, W/L, and Vds(sat) (Vds(sat)~0.3) to size transistors. Your way is an interesting way. I sure will give a try with your sizing tips and get back to you soon.
Steven
steven
Reply #13 - Jan 30th, 2006, 7:02pm
Hello Marc,
I tried the sizing method you suggested. Here are some followups and thoughts.
1. you are right that the ratio between PMOS and NMOS can easily mess sizes obtained from single tran sweep results. In other words, Vsd7 would be still too big even though individual tran has been sized correctly in single tran sweep. So when connecting PMOS and NMOS, the sizes have to be redone again. I hope I didn't do anything different than what you said regarding this.
Some sizes I adopted at single tras sweep are: NMOS (W/L)=200/0.5 leads to gm=14.5mS, PMOS (W/L)=500/1 leads to gm=12mS. Put them in the circuit place, Vsd7 is around 1.6 (after some minor tweaking), still too big.
2. I think using fT to pick gm should be the same as using Id, (W/L), and Vgs method in single tran connection. Besides, you may have other ways to choose fT, which is a function of parasitic cap also the transistor size and gm.
3. I think since Mb5 is simply to generate bias voltage for M1~M4, it may not require to have the same branch current as M1 and M2 branch. Of course, assuming the three branch have the same current can greatly siimplify the design.
Steven
Croaker
Reply #14 - Feb 1st, 2006, 7:37am
Re: 2  I prefer to pick my transistor sizes and biasing based on performance.  If you simply go with Id, Vgs, and W/L you could pick a small Vgs, big W/L, and big Id...getting a slow circuit with big transistors that burns lots of power.
Re: 3 If the PMOS is saturated, it should have roughly the same current as the other branches.
You are always going to have a Vds larger than Vds(sat) somewhere in the stack; you need to drop the voltage somewhere in the stack.
I would suggest trying something similar tothis topology from Baker's CMOS 2nd Ed.
Pages: 1 2
