May 21st, 2024, 5:59pm
Oscillator Gain Kvco (Read 7962 times)
hrkhari
Jan 20th, 2006, 7:10am
Hi Guys:
How to compute oscillator gain Kvco, for different tuning voltages?. Thanks in advance
Rgds
Jess Chen
California Bay Area
Re: Oscillator Gain Kvco
Reply #1 - Jan 20th, 2006, 8:28am
Are you asking about how Kvco is defined in general, how to compute Kvco analytically, or how to simulate a Kvco measurement? If you are asking about a simulation, we will need to know what tools you are using.
hrkhari
Reply #2 - Jan 20th, 2006, 6:48pm
Hai Jess :
I really want to know, how Kvco is obtained through simulation for different value of tuning voltages, for a given oscillator?. Currently I'm using Spectre-RF for the simulation. Thanks in advance
Rgds
trond
Glasgow, Scotland
Reply #3 - Jan 21st, 2006, 2:38am
To obtain the tuning sensitivity and linearity of your oscillator you need to run a swept PSS analysis. When setting up the PSS analysis you can enable the sweep button at the bottom and enter the control voltage as variable. Just specify the sweep range and number of steps. Once the simulation is finished you can click results, then direct plot, then main form, click on the harmonic frequency button, highlight the 1st  harmonic in the harmonic frequency section and press the Plot button. This will give you the frequency plot as a function of the control voltage. Kvco, or the sensitivity is just the derivative of this plot. You can use the calculator function deriv() to create this plot.
Hope this helps.
Sven
hrkhari
Reply #4 - Jan 21st, 2006, 7:39pm
Thx svensi
I have a problem in the setup of the PSS analysis of the designed -gm differential oscillator, I'm using a damped vsin source at the Vdd to start up the ckt, with a freq of 3.5G, amplitude 1mV and 50M of damping factor. Then I terminate the  ac coupled differential output by 50ohms port, respectively. The first question is do I have to convert the ac coupled differential output to single ended output using a balun, prior to 50ohms termination, for simulation prupose?. The second question is, when I use the damped vsin source as a start-up, PSS form setup does not finalize, stating a form error:
Periodic Steady State: Fundamental Tone 1 has a blank name
                                           For each tone that is not "Small" signal and has a SrcId listed, the schematic instance (SrcId) must have a name entered under
                                           the appropriate frequency  name property. Please edit the top level schematic  to assign these names, save the schematic and
                                           then click the "Update From Schematic" button on the analysis form.
This problem does not occur if I setup the PSS and then insert the start-up source to execute the simulation. Please advise
Rgds
trond
Glasgow, Scotland
Reply #5 - Jan 22nd, 2006, 1:50am
I am no expert, but I don't think you can have periodic sources in PSS in autonomous mode. Try using a pulse source for start-up, just don't specify a period. With independent sources used for start-up, set the PSS start time to a large enough value to be sure these sources are all inactive at the start of the PSS. Maybe someone else can give some more advice on how to solve your start-up problem.
sven
hrkhari
Reply #6 - Jan 22nd, 2006, 8:51am
Thnx again svensi
With regard to your earlier explanation in obtianing the Kvco plot, I had managed to obtain the 1st harmonic vs tuning voltage plot, but how do I select /search the function to deriv() in the calculator. Please do guide me.
Rgds
trond
Glasgow, Scotland
Reply #7 - Jan 22nd, 2006, 12:15pm
The deriv() function should be in the Special Function Menue in the calculator. You can select the wave you just plotted with the Wave button and then use the deriv() on it. For a full list of all the calculator functions you can look at the cadence manual files. You can use cdsdoc in a terminal to open those.
Sven
