Aug 16th, 2024, 1:16pm
Simulating power supply spurs in a VCO (Read 3733 times)
sjrg1980
Feb 01st, 2006, 3:06pm
Hello people,
                  I am trying to simulate the effect of power supply spurs and noise on the phase noise of the VCO.  In order to simulate the noise from the power supply I can include a noise file in the power supply in Spectre simulator.  That works. How do I simulate the spurs? Can it be simulated just like noise?
Ganesh.
wave3x
Shang Hai, China.
Re: Simulating power supply spurs in a VCO
Reply #1 - Mar 4th, 2006, 8:07am
I am also interesting in this topic, Anyone give me some suggestion?
Reply #2 - Mar 15th, 2006, 5:39am
Spurs are fixed-frequency (eg, 60Hz) components to what is supposed to be a dc supply, right?
So, you could put a small amplitude sine source in series with your dc voltage source.
Vdc (extra 0) vsource dc=5.0
Vspur (vdd extra) vsource type=sine freq=60 ampl=1u
where "vdd" is the net where the dc source was originally attached.
Reply #3 - Mar 15th, 2006, 8:44am
You can also apply the unwanted signal that is causing the spur as a small signal and compute the transfer function from where the signal is applied to the output of the oscillator using PSS/PAC or PSS/PXF. This works well if the spur is small.
