Aug 16th, 2024, 3:13pm
Setting of "number of harmonics" in PSS (Read 6228 times)
rintel
Mar 17th, 2006, 6:58am
Hello all,
I am simulating a mixer with PSS and PXF. The setting of "number of harmonics" in PSS seems to affect a lot on the spectrum ploted by PXF voltage gain. There can be 20dB difference on the LO harmonic response, if I choose the "number of harmonics" to be 0 or 20. The output of mixer is zero-IF. I think the maximum sideband option in PXF should matter, but why the "number of harmonics" in PSS also affect in this case? Any discussion on related topics will be appreciated!
Best regards,
Rintel
Re: Setting of "number of harmonics" in PSS
Reply #1 - Mar 17th, 2006, 9:13am
Changing the number of harmonics in the initial PSS analysis should only indirectly affect the results from a subsequent PXF analysis. It can affect it because setting the number of harmonics places a bound on how large the timestep can be in the PSS analysis. If changing the number of harmonics strongly affects the PXF results it implies that the PSS analysis is not producing accurate results. This might be because you have widely spaced frequencies and signal sizes present in the circuit. You might consider tightening tolerances a bit in the PSS.
rintel
Reply #2 - Mar 17th, 2006, 11:27am
Thank you Ken!
I have tried your suggestions. Set errpreset in PSS to conservative, and maxstep to 1/10 of LO period. Also I set tolerance in PXF to 1e-5. There are some change on the results at least. But the difference is still big. It seems to me that when "number of harmonics" is 0, the result is less accurate. Is it fair to guess that larger "number of harmonics" tends to give more accurate simulation? Is there any other way to make sure which is the accurate one?
rintel
Reply #3 - Mar 17th, 2006, 2:17pm
Something does not seem right. Take a look at the value used for maxstep as reported in the "important parameters" section of the log file. If you manually set maxstep in the 0 harmonics case to be smaller than that used by Spectre in the 30 harmonics case, then changing the number of harmonics should not affect PXF. It it does, something else is going on. IN that case you should probably contact Cadence for an explanation.
rintel
Reply #4 - Mar 19th, 2006, 10:31am
I tried your suggestion again. The setting of important parameters, including 'maximum step', in both cases, are exactly the same. It seems no way to resolve the problem. Also to contact Cadence is unlikely to be realistic, because the process as I read online is really complicated...
Anyway, thanks for help!
-Rintel
Reply #5 - Mar 30th, 2006, 5:20am
Why are you setting the tolerance in PXF to 1e-5? That's much larger than the default of 1e-9. Leave it alone...
You've probably degraded the PXF accuracy considerably.
