Jul 23rd, 2024, 8:38am
How to define digital high level to a specific val (Read 3533 times)
bernd
Munich/Germany
Feb 03rd, 2006, 8:13am
In a Cadence DFII analog environmet mixed-signal simulation
no matter if it is AMS or SpectreVerilog,
the high level of the digital signal is always 5V,
if it is displayed in the same waveform window as the analog signal.
This happens in AWD as well as in WaveScan.
In WaveScan there is an additional option d2aDialog which could create
a derivate waveform from the digital one and put it on the right level.
Question, does anybody know how to initialy define the digital
high level equal to the supply voltage?
Thanks Bernd
PS: This is not an issue of interface elements or connect rules.
Just another lonesome cad guy
Re: How to define digital high level to a specific
Reply #1 - Feb 5th, 2006, 8:43am
For AWD there's a private function:
awviSetLogicLevels(1.0 4.0)
which sets the low and high voltage levels - but it's private. However, since AWD is going away in IC610, I don't see much danger in using it...
For wavescan there's cdsenv settings:
wavescan.trace dToAHiVoltage string "5.0"
wavescan.trace dToALoVoltage string "0.0"
wavescan.trace dToAXVoltage string "(vhi + vlo)/2"
wavescan.trace dToAUnit string "V"
I've not tried the wavescan settings, but I think these should do what you want.
bernd
Munich/Germany
Reply #2 - Feb 6th, 2006, 1:12am
Thanks Andrew that's exactly what I was looking for.
I've overlooked the entries in .../dfII/etc/tools/wavescan/.cdsenv
Bernd
