venky
Does anyone know how to build a piecewise linear switch ( A switch whose resistance varies with input voltage). Background of the problem : In switch cap circuits typically the initial design is done with ideal switches. These ideal switches go from ON resistance of a few ohms to OFF resistance of teraohmes(which u can set) . Such abrupt changes in resistance causes convergence issues in spectre. If we can build a switch which changes its resistance in linear way then simulators should not have that problem.
