Aug 15th, 2024, 11:36pm
input/output impedence in Hspice (Read 2308 times)
brandano
Feb 08th, 2006, 3:38am
to calculate the input impedence of a RF circuit, in Hspice, is the only one way to make a .NET analysis??  I mean, whit just an .AC analysis I think it's impossible, because Hspice do not have the function to calculate the real part and imaginary part of an expression...........I suppose!
thanks,
davide
Re: input/output impedence in Hspice
Reply #1 - Feb 8th, 2006, 5:38am
You can print the imaginary part of a voltage or current in an ac analysis:
.print ac vi(n1)
With a little creativity, you might be able to re-write your expression from imag(f(v(n1), v(n2), ...) into g(vi(n1), vi(n2), ...)
