fab_jor
Brasil
Firstly, sorry for my poor english...
I am having some troubles in my project. I am designig a double balanced mixer CMOS which uses a PMOS as a active load ( current source, exactly ). The RF and LO ports are perfectly matched, but the IF port no. While I got an excellent IIP3 point ( +14.2 dBm ) and reasonable Noise Figure ( NF = 14.4 dB ), my circuitīs conversion gain is low ( CG = -7.7 dB ). I use a current of, approximately 12 [mA] and the transistorsīdimensions are : W_RF=200 [um] and L_RF=L_min ( 0.25 [um] ), W_LO=300 [um] and L_LO=L_min and, the active loads, W_AL=650 [um] and L_AL=0.35 [um]. I got these values to estipulate DC voltages on especific nodes. For example, the DC voltage at IF node is 2.4 [V] ( VDD = 3.3 [V] and TSMC 0.25 [um] process ). Please, can you help me ? I need a better CG... I am sending the schematic attached.
Thank you very much.
