Jul 19th, 2024, 1:14am
how to generate a negative reference voltage (Read 5274 times)
zychang
Ireland
Feb 16th, 2006, 9:01am
I'm currently designing a switched-capacitor circuit for a mixed-signal system. It is a multiply-by-2 circuit using fully differiential opamp. Now, I have a little question on the negative reference voltage for the SC and I'm just wondering if there is somebody know about this issue by any chance. The positive reference I have is coming from a bandgap reference circuit, which also supply the current needed in the opamp. I just have some difficulty to generate the negative reference voltage. I have seached on the web for some time but no solution found so far. I thought maybe I could use an opamp sitting in a feedback configuration to invert the positive voltage, but it seems to me an very inefficient way.
Any comments will be well appreciated.
Mike
zhc
Re: how to generate a negative reference voltage
Reply #1 - Feb 16th, 2006, 10:59am
One common way is to not generate negative reference voltage at all. You
can configure the switches in a way that dumps negative charge to the summing
node. You need two copies of the switched capacitor resistor for this.
Some other people just use Vdd and GND as the positive and negative reference.
Best regards,
zhc
Paul
Switzerland
Reply #2 - Feb 16th, 2006, 12:43pm
I don't fully understand your question. You are designing a fully differential circuit, so the negative reference should be readily available by cross-connecting the capacitors. Am I missing something?
Paul
zychang
Ireland
Reply #3 - Feb 17th, 2006, 7:39am
Thanks for your comments, guys.
Ok, I'm trying to describe it in more detail. What I'm designing is a multiply-by-2 circuit. As it is bit like the 1.5bit stage in pipline ADC, a positive reference and a negative reference voltage are needed. I can think of two ways of generating these voltages: one is to build a differential reference voltage, like the one mentioned in Razavi's book, so that a negative reference voltage can be realized by cross-connect the capacitors, just like you said in your post Paul. But I found some difficulties in designing the differentianl reference voltage circuit, so I just moved to the second approach(maybe not commonly used by people around but this is the way I can think of since I just started in this area), which is to build two single-end reference voltages. Now, I have no problem building the positive one, but I just have no idea how to realize the negative one. I don't know if the cross-connecting thing is still working here. Also, I have found some thesis on pipeline ADC from the websit of P.Gray's group in UC Berckley, some of them seem to use capacitors array to provide the reference voltage which is a quite different idea from mine. So, if you can give me some advice or reference or what people normally do in this topic, I will very appreciate it.
thanks again.
steven
Reply #4 - Feb 17th, 2006, 12:16pm
zychang wrote on Feb 17th, 2006, 7:39am:
Sorry my interruption to your question: since you said you had no problem in producing the positive one and according to the book, you should be able to get the negative one, right? I think I must have misunderstood you. Which section of Razavi's book reference you are referring to (Chapter, page etc)?
zychang
Ireland
Reply #5 - Feb 17th, 2006, 1:04pm
Hi steven,
The positive one I use is coming from a very simple bandgap circuit, which can be found in P391 (Fig. 11.20) in Razavi's book (Chapter 11). I was just wondering if it is a good idea to use two single-end reference voltage generators for the multiply-by-2 circuit. I was thinking of using a differential reference voltage generator, which is quite similar to the one mentioned in that Chapter (Fig 11.32 p399), but I just had some difficulties there, such as the design of the amplifer (A1 as in the book). would u please let me know what reference circuit is normally used in this kind of situation.
Best regards
Paul
Switzerland
Reply #6 - Feb 20th, 2006, 1:00pm
Coming back to the differential design, it seems one of us is missing something... In a differential design, you have to have to nodes for the reference voltage, which I will call Vrefp and Vrefn. If you connect your capacitors in a straight connection (C1 to Vrefp and C2 to Vrefn) this will make +Vref. If you cross-connect the capacitors (C2 to Vrefp and C1 to Vrefn), you will get -Vref.
You don't need to build a negative voltage reference on-chip. (Vrefp, Vrefn) could be (VDD, GND) as suggested before, it could also be (VDD/2+x, VDD/2-x) where x is a voltage to be defined in your design. One solution to obtain these voltages would be the implementation of a bandgap voltage reference generating two copies of a CTAT (constant to absolute temperature) current. Sending these CTAT currents into two different size resistors, you get two very stable voltage references of different values. This would correspond to your two single-ended voltage references, I guess.
Paul
