Aug 31st, 2024, 6:28pm
physical parameter in bsim3v3 (Read 1578 times)
pbs681
Feb 17th, 2006, 6:48pm
Can somebody help me to list all the phycical parameter in bsim3v3? thx
Paul
Switzerland
Re: physical parameter in bsim3v3
Reply #1 - Feb 20th, 2006, 12:19pm
You can find the model documentation on the official web site:
http://www-device.eecs.berkeley.edu/~bsim3/get.html
Hope this helps
Paul
pbs681
Reply #2 - Feb 21st, 2006, 4:28am
Paul wrote on Feb 20th, 2006, 12:19pm:
Hope this helps
Paul
Thanks Paul for the website. But what I mean here is that, from more than hundred parameters in MOS model, which one is carrying physical meaning... ie tox, cj.... we know that these parameters (MOS model) are mixing of empirical and physical parameters
bernd
Munich/Germany
Reply #3 - Feb 21st, 2006, 5:12am
Maybe
spectre -help bsim3v3
helps, if you are a Spectre user.
Bernd
Just another lonesome cad guy
Reply #4 - Feb 21st, 2006, 6:26am
[quote author=pbs681 link=1140230903/0#2 date=1140524905]Paul wrote on Feb 20th, 2006, 12:19pm:
pbs681 -
I don't think your question is well posed.  For example is CJ really physical?  One could argue that it is a fitting parameter for the capacitance per area of the source/drain diffusion; the junction itself is probably not abrupt nor linearly graded.  I think there's a continuum of sorts from the "truly physical" parameters like TOX to the "strictly empirical" parameters like VOFFCV.  And many parameters probably have default values that are computed from physical values, but you can tweak them to fit the measurements better.  (Eg, CGBO has a default value of 2*DWC*COX, which is physical, but what if you change it to 1.8*DWC*COX?)
Probably your best bet would be to find an extraction guide for BSIM3, which would tell you what parameters you could fill in "good values" for from physical process information.
-Geoffrey
pbs681
Reply #5 - Feb 22nd, 2006, 3:45am
[quote author=Geoffrey_Coram link=1140230903/0#4 date=1140531974]pbs681 wrote on Feb 21st, 2006, 4:28am:
pbs681 -
-Geoffrey
Hi Geoffrey,
I totally agree with you. My question was not well posed since I am still new in this field. That is what I mean. Sorry for that. Anyway I have question regarding Cj. In order to extract the Cj, we draw special test structure that include the Cj requirement extraction, ie area intensive and prephery intensive test structure. That means, Cj is directly extracted from the structure and not from the calculation. That is why I am reffering this parameter as a physical parameter. Is it correct?
Where can I find an extraction guide for BSIM3. Really appreciate if anybody can help on this.
Reply #6 - Feb 24th, 2006, 6:21am
This web page http://www.eecs.berkeley.edu/IPRO/Software/Catalog/Description/bsim3v2.0.html says that an extraction guide for BSIM3 is available for $1.  You may find it for free if you spend enough time with Google.
pbs681
Reply #7 - Feb 24th, 2006, 7:28am
Geoffrey_Coram wrote on Feb 24th, 2006, 6:21am:
Thanks Geoffrey. I will try to get it.
