May 21st, 2024, 1:40pm
Simulating a VCO (Read 2465 times)
shortckt
Washington
Simulating a VCO
Feb 20th, 2006, 12:07pm
Can anyone please tell me that how to setup MOS Varactor in Spectre (Schematic) while designing a LC VCO. Should I put a variable (Vcontrol) at gate and use it as one plate and short drain and source to use it as other plate of capacitor.  If yes, then what are the steps to sweep the control volatge to see the frequency change?
I am new to VCO design. Please help!
Thanks.
shekar380
Re: Simulating a VCO
Reply #1 - Mar 17th, 2006, 10:42pm
hello
instead of using a single MOS CAP u can  connect two mos caps in series so that the gates of two transsitors  act as two ends of the capacitor and the S/D terminal of the two transistors shorted together can act as thetuning control.
ground one end of the capacitor and connect a sinusoidal source  with required DC level(say 1.0V) to the other end.Let the frequency  ofthe source be that value for which u r designing ur VCO.
do a parametric sweep of the control voltage and  measure   rms(i)/ rms(dv/dt).This gives  a graph  showing the capacitance variation.The limits of the CAP variation gives the tuninf frequency limits accordingly.
regards
shekar
judean1
Reply #2 - Mar 21st, 2006, 3:00am
First of all in designing the mos varactor, you should fix what type of device you are going to use and the region of operation of the device ( depending upon where the voltage at the control pin), as mos can act as a varactor in all the three region, viz. accumulation, weak inversion and strong inversion.
Try using a PMOS based varactor, where the device acts in inversion region and you can integrate it with the charge pump LPF combination in future. Further simulating and charactersing PMOS based varactor in inversion region can be done witht he BSIM3v3.x model files with certain other apporoximation.
In this varactor design, the gate acts a one plate and the source-drain short acts a the another one, donot forget to connect the substrate to VDD, to always keep the transistor in inversion region. Apply the varialble voltage to the gate and connect the other terminal of the mos cap to the oscillator arm.
Hope this helps.
regards,
V
