Jul 16th, 2024, 11:42am
Performance/area tradeoff using several multiplier (Read 2263 times)
rahulfloyd
Feb 20th, 2006, 5:38pm
Incase we use several, say 4, multipliers in parallel, to get a multiplication result in 1 clock cycle...as compared to a single cycle multiplier requiring 4 clock cycles to get the same result -
Would the increase in area on chip using the 4 parallel multipliers outweigh the improvement in performance (speed of operation) over the single cycle multiplier?
jbdavid
Re: Performance/area tradeoff using several multip
Reply #1 - Apr 21st, 2006, 2:10am
depends on your design criteria..
is area more important than the number of clock cycles.. or the other way around..
no "right" answer here untill you take your customers needs into account...
Jonathan
jbdavid
