Jul 18th, 2024, 11:18pm
Characterizing a current mirror (Read 5403 times)
Croaker
Feb 22nd, 2006, 6:59am
Hi all, what things are important when trying to characterize a current mirror?  Here are the things that come to mind:
input resistance
output resistance
dc current transfer ratio
frequency response (applying AC current signal to input and observing current output)
output current vs. output voltage (dc sweep)
Are there any others that are important?
Marc
huber
GO BEARS!
Los Angeles
Re: Characterizing a current mirror
Reply #1 - Feb 22nd, 2006, 7:39am
Mismatch?
Croaker
Reply #2 - Feb 22nd, 2006, 7:54am
huber wrote on Feb 22nd, 2006, 7:39am:
Mismatch?
Oh yeah!  I think that is captured in the DC current transfer ratio (Iout/Iin).  If you get a 1:1 transfer you have no mismatch.
Paul
Switzerland
Reply #3 - Feb 22nd, 2006, 12:25pm
Hi Marc,
I believe output current vs output voltage corresponds to the output conductance/resistance you also mention. I would add that noise may be an issue in some cases. I would also mention that Iout/Iin both includes static offset and mismatch.
Paul
Croaker
Reply #4 - Feb 22nd, 2006, 1:47pm
Paul wrote on Feb 22nd, 2006, 12:25pm:
Hi Marc,
Paul
Noise...of course...good catch!  :)
Is a systematic offset a big deal?  I mean, if you know what your current offset is, you should just be able to adjust Iin to get the Iout you want, right...?
Right, I would typically plot Iout vs. Vout and then take 1/derivative(Iout) to get Rout.
Marc
vivkr
Reply #5 - Feb 23rd, 2006, 1:39am
Hi Marc,
I would say that systematic mismatch is an issue if you want precise currents, because you may know the
systematic mismatch at one corner (process, voltage, temperature), but it is unlikely to be the same
across all (P,V,T) corners.
Whether the mismatch is critical or not is largely dependent on the application. For instance, it would
be fatal in a current-steering DAC, but may be a little less serious in an opamp.
However, a significant amount of systematic mismatch is a sign of a poorly designed mirror, and may
be an indirect sign that your output impedance etc. are poor. You should ask yourself why there is systematic
mismatch. You have the same VGS, same (W/L) or a fixed ratio. The only variation comes from the VDS
variation, and if this causes significant deviation in the mirror ratio, then you will run into trouble with
some other critical parameter such as gain or PSRR.
So pay attention to the mismatch is what I would say.
Vivek
sonny
Reply #6 - Feb 25th, 2006, 6:12am
Over drive voltage is important. It decide output inpedance and noise.
Longer L brings high over drive voltage and good current ratio matching.
jjsnail
Reply #7 - Mar 9th, 2006, 2:32am
hi vivkr
 how to analyze the systematic  mismatch of a current mirror?
can U give a example?
