Aug 31st, 2024, 10:09pm
Vth Shift( Positive or Negative?) (Read 4106 times)
jason_class
singapore
Feb 22nd, 2006, 11:29pm
Hello All
I would like to seek advice on threshold voltage shift of cmos.
Let's say there is sodium contamination on the cmos device, will both nmos and pmos experience positve threshold voltage shift (both with increasing Vth?)?
I try to relate the sodium contamination with Qi/Ci where Qi  is the charge in oxide.
As flat band voltage is Vfb= Vms - Qi/Ci , so I guess both will show the decreasing or increasing threshold voltage.
Kindly enlighten.
Thank you all
best regards
Jason
Croaker
Re: Vth Shift( Positive or Negative?)
Reply #1 - Feb 28th, 2006, 1:49pm
Qi/Ci is positive for both PMOS and NMOS (the interface charge, Qi, is positive).  So, the Vfb term you mentioned is more negative for a larger contamination (Qi/Ci is bigger)
Vfb = Vms - Qi/Ci
Vth = Vfb + ...
For NMOS, Vth is more negative (threshold is lower).
For PMOS, Vth is more negative (threshold is higher, since it has a more negative Vth)
I.e.
VthNMOS = 1 - 0.1 = 0.9 (better)
VthPMOS = -1 - 0.1 = -1.1 (worse)
I assume you want minimum threshold voltages.  This might not be desirable for low leakage currents.
I hope that cleared things up.
Cheers,
Marc
jason_class
singapore
Reply #2 - Mar 2nd, 2006, 5:05am
Hi Murphy
That explains everything clearly !
Thank you so much
best regards
jason
