Oct 5th, 2026, 5:18pm
how to read and write in same file in verilogA (Read 3876 times)
Badri
Bangalore, India
Feb 23rd, 2006, 3:11am
I want to perform multiple read and write  operations on the same file in verilogA. How can I achieve this?
Badri
View Profile bszanwar2000@yahoo.co.in   IP Logged
Re: how to read and write in same file in verilogA
Reply #1 - Feb 24th, 2006, 6:15am
Are you not able to $open and $close the file multiple times?
Marq Kole
Eindhoven, The Netherlands
Reply #2 - Mar 20th, 2006, 2:36am
Maybe this is too obvious, but you have to be able to open a file with 'r+' or 'a+' mode (read-update, or append-update) to be able to read and write the same file. That is only possible if your tool is Verilog 1394-2001 compliant. The 1995 standard, on which Verilog-AMS 2.2 is based, only supports writing, except for loading memory data from a file.
Even if the digital part of your simulator correctly supports the Verilog 2001 syntax, the analog part may not if that is provided by another vendor.
Essentially, it depends on what you are trying to achieve.
