Aug 16th, 2024, 9:30am
Noise Figure (Read 2056 times)
RF_Guy
Noise Figure
Feb 26th, 2006, 2:46am
Does anyone know how I can simulate the Noise Figure my circuit? How should I specify the .noise analysis ?Thanks a lot.
Re: Noise Figure
Reply #1 - Feb 26th, 2006, 7:51am
It would help if you said which simulator you're using.
If spectre, all the noise analyses will compute noise figure if the input source is specified as a port, and you tell the noise analysis that the source is the input... (you normally want to specify the output as a probe, and probe the load port or resistor, to ensure that the noise from the load is excluded from the measurement).
The fact that you said ".noise" probably means you're not using spectre though...
