jason_class wrote on Mar 2nd, 2006, 4:27pm:Hi Murphy and All
I would need some advice on Vfb and Vt for a practical nmos and pmos,
I am thinking that when an nmos is at 0V for the gate voltage, what will the nmos condition be.
Is it at flatband , depletion or?
That depends on whether it is an enhancement or depletion device.
jason_class wrote on Mar 2nd, 2006, 4:27pm:I am thinking if device designer MUST always design pmos and nmos to work at exactly flatband when the gate voltage is applied to turn the device off.
This is because I am trying to understand how Vt requirement is when gate voltage is 0V for nmos. Has nmos reached just nice at flatband when its gate at 0V, so any increse in Vg will just turn the nmos on by supplying the voltages across depletion region and inversion charrges?
or it still need some voltage to make it flatband ?
No, the device does not have to be at flatband at Vgs=0 V - that assumption is messing you up. It is however true that the traditional definition of Vth is the voltage it takes to go from flatband to having the same carrier concentration as the substrate (but with the opposite polarity).
Any application of a voltage is going to affect the region under the gate whether it's at flatband or not. More voltage causes more inversion. Think of the flatband condition as the neutral condition, where the surface has the same carrier concentrations as the bulk. It doesn't matter whether the device is flatbanded at Vgs=0. If the device is already a bit depleted at Vgs=0, it just means a lower voltage is required to invert the channel. This is what you'd like for a low Vth device. If you want a depletion device you make it so the channel is already inverted at Vgs=0.
Basically the flatband voltage is just part of the threshold. This is what Vfb is all about...the NMOS device is already a bit depleted because of the work function difference and trapped charges, so Vth is lower that it would be if you didn't account for work fn. diff. and trapped charges.
The higher Vth is, the smaller the amount of inversion will be at 0 V. Different devices will have different Vth values; no problem.
Cheers,
Marc
