Apr 28th, 2024, 4:44pm
problem with spectre and neocircuit (Read 2822 times)
danda821
Mar 04th, 2006, 2:04pm
When I run NeoCircuit 'get output', a spectre simulation is launched and it
give the following error. Anyone know what is the problem? Thank you.
cpp: unrecognized option `-$'
spectre (ver. 5.0.33.092203 -- 23 Sep 2003).
Error found by spectre during circuit read-in.
   "netlist.final" 5: Syntax error in specification of `spectre//'.
   "netlist.final" 7: There can be at most one global statement and, if
       present, it must be the first command in the file (after title or
       language directive).
spectre terminated prematurely due to fatal error.
..(See 'Eval Errors' panel for full text of error message.)
Re: problem with spectre and neocircuit
Reply #1 - Mar 15th, 2006, 5:20am
That seems like a rather old version of Spectre.  Can you update to 5.1.41 or MMSIM6 (6.0.???)?
