Sep 1st, 2024, 10:18am
about P+ poly gate (Read 1683 times)
jason_class
singapore
about P+ poly gate
Mar 08th, 2006, 7:27pm
Hi Murphy and All
I come across text that mentioned p+ poly gate for nmosfet has Vfb as
Vfb= +Eg/2q  - (Vb).
Can you please help to explain how do we come out with the positive sign of +Eg/2q and negative sign of Vb?
Then Eg, q and Vb are in the absolute values right?
Kindly enlighten
Thank you Murphy and All
best regards
Jason
Croaker
Re: about P+ poly gate
Reply #1 - Mar 14th, 2006, 8:20am
I'm not sure what your variables mean.  What is Vb?  Are these the levels in the poly or in the substrate?
jason_class
singapore
Reply #2 - Mar 14th, 2006, 4:32pm
Hi Murphy
Thank you for spending time on my enquiry.
Vb is the separation between the Ei and Ef at the substrate side (The potential)
As for Vfb flatband voltage but in the equation, the Qi/Ci is assumed to be zero ,
making Vfb= Vms
Eg is the bandgap energy
I saw in the book for the below 3 cases;
1) n+ poly gate on p silicon, Vms= - (Eg/2q)- Vb
2)p+ poly gate on n silicon , Vms = +(Eg/2q) +Vb
3)p+ poly gate on p silicon , Vms = +(Eg/2q) -Vb
Do you know how to get the equation for the 3) case?
That is my exact question.
Kindly enlighten
Thank you Murphy
best regards
jason
Croaker
Reply #3 - Mar 15th, 2006, 8:02am
I'd have to look at the book or see where the equations come from.
Good luck,
Marc
jason_class
singapore
Reply #4 - Mar 15th, 2006, 4:02pm
Hi Murphy
The book is written by Yuan Taur and Tak H Ning.
Title is Fundamental of Modern VLSI Devices.
Page 75 and 188.
Thank you Murphy
best regards
jason
Croaker
Reply #5 - Mar 15th, 2006, 9:47pm
jason_class wrote on Mar 15th, 2006, 4:02pm:
Hi Murphy
Page 75 and 188.
Thank you Murphy
best regards
jason
The 1998 one?  I will check it out from the library and see if I can see what you are asking about.
jason_class
singapore
Reply #6 - Mar 16th, 2006, 6:51am
Yes Murphy
There are reprints done for each year up to 2002 as I can see. Maybe there are even newer ones.
The one I am loaning is  year 2002 which is exact reprint from year 1998.
Thank you for the help
best regards
Jason
vivkr
Reply #7 - Jun 20th, 2006, 5:09am
jason_class wrote on Mar 14th, 2006, 4:32pm:
Hi Murphy
making Vfb= Vms
Kindly enlighten
Thank you Murphy
best regards
jason
Hi Jason,
You can derive all three equations very easily in the following manner:
1. Draw the band diagram of the bulk semiconductor, and of the gate polysilicon separately.
Both have the same Ec (Conduction band), Ev (Valence band) and Ei (Intrinsic level). Only the Ef (Equilibrium Fermi level) is different.
2. The bulk is lightly doped and so (Ei-Ef) is finite. For the gate, assume that Ef is either at Ec (n+ gate) or Ev (p+ gate).
3. Now, the Vfb can be easily found by taking the difference of potentials that would be required to align the 2 Fermi levels on either side.  The (Eg/2q) is just half the bandgap.
For your first question, (p+gate on p bulk), Ef(gate) = Ev.
Thus, aligning the 2 sides needs the gate to be raised up by Ef(bulk)-Ev which is equal to
(Ei-Ev)-(Ei-Ef(bulk)) = (Eg/2) - q*Vb
You can derive the other 2 equations in a similar manner.
Vivek
