Aug 16th, 2024, 5:33am
theory of cyclostationary noise (Read 2103 times)
modern_analog
Mar 11th, 2006, 3:16pm
i understand how modulation causes a frequency upconversion/downconversion. this is the basis of LTV versus LTI analysis
The confusing thing: some papers talk about non-linearity and it causing frequency upconversion. Again that makes sense
How are the 2 related or waht is correct? Please help!!
Re: theory of cyclostationary noise
Reply #1 - Mar 12th, 2006, 2:04pm
Nonlinearity by itself does not directly result in frequency conversion. Rather, the characteristics of the circuit are modulated by the presence of a large unrelated signal such as an LO if the circuit is nonlinear. Thus, if the large signal is periodic, it acts to periodically modulate the characteristics of the circuit, characteristics like effective gain. Thus, to the information signal, which we will assume is small, the circuit appears as if it is a periodically time-varying linear circuit, and that is what causes the frequency conversion.
