Spectre can parse Spice syntax, so you should be able to use the HSpice-style .model card -- particularly if you're using the .lib statement, which is also Spice.
We usually use Spectre format:
simulator lang=spectre model mn mos1 type=n vto=0.7 gamma=0.4 lambda=0.05
What LEVEL are you using? vth0 is a BSIM3/4 parameter (level=1 uses vto), but gamma is a level=1 or level=3 parameter (bsim3v3 has gamma1, gamma2 but no gamma).
