Jul 2nd, 2025, 6:09am
what is the spectre format of mos transistors ? &n (Read 5820 times)
zhonghan
china
Mar 20th, 2006, 1:42am
i just want to write a simplest spectre model by myself. I know the format in  Hspice , like
   .model  mn nmos  vth0=0.7  gamma=0.4 lambda=0.05.  what is the coresponding format in spectre( incuding version )?
Then how to cite this model in spectre , I know " .lib 'path'  corner " in HSPICE is just ok .
Re: what is the spectre format of mos transistors
Reply #1 - Mar 20th, 2006, 4:15am
Spectre can parse Spice syntax, so you should be able to use the HSpice-style .model card -- particularly if you're using the .lib statement, which is also Spice.
We usually use Spectre format:
simulator lang=spectre
model mn mos1 type=n  vto=0.7  gamma=0.4 lambda=0.05
What LEVEL are you using? vth0 is a BSIM3/4 parameter (level=1 uses vto), but gamma is a level=1 or level=3 parameter (bsim3v3 has gamma1, gamma2 but no gamma).
zhonghan
china
Reply #2 - Mar 20th, 2006, 7:36am
Thank you , I have resolved this issue.  you are right , I just  copy the "vth0 " from a bsim3v3  model. By the way ,do you know the simple way to calculate the Ro of transistors with a bsim3v3  model?
Reply #3 - Mar 22nd, 2006, 9:18am
There's not an easy way directly from the parameters, but I think you get it from the slope of the Id/Vd curve (or 1/Gds for a Vd sweep).
zhonghan
china
Reply #4 - Mar 24th, 2006, 11:07pm
I know the 1/ro is  equal to the slope of the Id/Vd curse. But the ro is dependent on the operating point,   in the other word dependent  on the Vgs. So does it  mean I should get  different  ro  under different  Vgs ?
Reply #5 - Mar 27th, 2006, 3:26am
Yes, you should.  I suppose, if you are in saturation, then the Id/Vd curves are nearly parallel for different Vgs, so ro will not be strongly dependent on Vgs.
