May 18th, 2024, 3:52am
Can CDL netlist automatically be in upper case? (Read 9063 times)
vibren
Mar 23rd, 2006, 7:14pm
I want all characters in the CDL netlist to be in upper case, what should I do?
thanks
bernd
Munich/Germany
Re: Can CDL netlist automatically be in upper case
Reply #1 - Mar 24th, 2006, 1:40am
Write a Perl script!
The information you gave is not detailed enough.
You should at lest tell which tool produces the CDL output.
Additional information could also help, e.g.  where you need the CDL as input,
why you need to have all Chars in upper case, etc..
If you write that kind of spare questions don't wonder if you get
no or less feedback.
Bernd
Just another lonesome cad guy
vibren
Reply #2 - Mar 25th, 2006, 9:43pm
I am sorry
I export the CDL netlist from a composer schematic. That is, I export it from CIW-> CDL-> export. The layout guys need the netlist to be all in upper case.
bernd
Munich/Germany
Reply #3 - Mar 30th, 2006, 1:54am
I thought there could be a mapping within the CDL OUT
process form Cadence DFII, but unfortunately I found none,
even not with SKILL.
But a simple Perl Script can make it.
#!/usr/local/bin/perl -w
use strict;
my( $file );
print( "File: " );
$file = <STDIN>;
chomp( $file );
open( IN, "$file" ) ||
	die "Can not open file. $!\n";
open( OUT, "> $file.upper" );
while ( <IN> ) {
		print( OUT uc( $_ ) );
close( IN );
close( OUT );
Bernd
Reply #4 - Mar 30th, 2006, 5:45am
 tr a-z A-Z < inputfile > outputFile
will do this. On Solaris, you need to get the tr from /usr/xpg4/bin for this syntax. Other tr flavours have different syntax.
man tr is the best bet.
Shorter than a perl script!
graywang
Reply #5 - Oct 18th, 2006, 6:40pm
hi,
I think it is a easy problem.you can tell layout designer to conform the case sensitivity to you. "Export→Stream→Options→Case sensitivity".
Do you agree to my idea?
Thanks.
bernd
Munich/Germany
Reply #6 - Oct 19th, 2006, 2:14am
Sorry to do some bit of education here, but this
is a quite old posting and it's definitely solved!
And "Export→Stream" exports GDSII format, but never CDL.
So you total wrong.
Bernd
