Aug 17th, 2024, 11:15pm
Ref Voltages to Comparator in MDAC (Read 2292 times)
packiaraj
India
Mar 23rd, 2006, 8:11pm
Hi Forum,
            I am verifying a Recirculating Pipelined ADC design. It is 10 Bit, 1MSPS design. Positive Input INP can swing from 2V to 1V and Negative Input INN=1V. Common Mode Voltage for OPAMP is 1.5V. It is 1.5Bit/Stage design. We have 2 such stages. The output residue of second stage is fedback as input to the first stage. For the first clock cycle SHA output will be sampled by first stage. For the rest of 9 clock cycles the first stage will sample the residue fedback by the second stage. The second stage will always sample the residue output of first stage.
           In this design, we have 2 coarse comparators (Fully Differential Dynamic) in MDAC stage. The Interstage gain is  2. The SHA output swing is from 1V to 2Volt with CM=1.5V. I see from the design the whole input range is divided by 8. i.e., (2-1) /8=0.125V. The reference voltages applied to comparator are 1+3/8(0.125)=1.375 and 1+5/8(0.125)=1.625. . When the input is in the range [1:1.325) the thermometer code output of comparators is 00. For [1.325:1.625], it is 01 and for (1.625:2], it is 11. When output is 00 , 1V will be selected for subtraction, when 01, 1.5Vwill be selected, when 11, 2V will be selected for subtraction in generating the residue. But, When I simulated the top level design I saw too much of missing codes.
           But to my understanding the reference voltages should be -Vref/4 and +Vref/4. In this case (2-1)/4=0.25., 1.25V and 1.75V instead of 1.375 and 1.625. What could be the exact values comparator reference voltages for this design? Ur input is invaluable........ Please help.
Packiaraj.V.
packiaraj
India
Re: Ref Voltages to Comparator in MDAC
Reply #1 - Mar 26th, 2006, 8:04pm
As I could not see any reply I preferably assume that my question is not clear. Let me come from the paper which I referred. It is "A 1.5-V, 10-bit, 14.3-MS/s CMOS Pipeline Analog-to-Digital Converter ", A ABO, PR GRAY, IEEE JSSC May1999". In Fig.3 (2nd page), If -Vr=1V, +Vr=2V what would be -Vr/4 and +Vr/4?. For the MUX the inputs are -Vr=1 V, 1.5V and +Vr=2V respectively. The common mode voltage for OPAMP is  1.5V (In this Fig. the CM voltage is 0). Can any one help me now what is +Vr/4 and -Vr/4?
Thanks in advance,
Packiaraj.V.
yvkrishna
Reply #2 - Apr 25th, 2009, 1:51pm
Hi Packiaraj,
Not sure if you are still looking for answer to this and this may be useful to others,
but answer is when the total range of inputs is -Vr to +Vr , your statem of -Vr/4 and +Vr/4 for comparators is correct,
In your case the effective Vr would be (2-1)/2 =0.5; so Vr/4 = 0.125
Now the comparator references would be +/- Vr/4 around the centre value{i.e, (2+1)/2=1.5}
1.5-0.125=1.375  and 1.5+0.125=1.625.
Hope this is clear.
vamshi
