coo848
I use modelsim in vhdl design. I want to call data from fetalint.txt. my code is
use std.textio.all;
file infile: text is in "fetalint.txt"; variable ip1: integer range -4096 to 4095; variable buf: line; process begin while not(endfile(infile)) loop
readline(infile,buf); read(buf,ip1); W_data<=ip1;
wait until falling_edge(W_clock);
end loop;
After i compile it, it succeed with WARNING: C:/Program files/Modeltech_xe/examples/fetalfirV2_tb.vhd(53): Using 1076-1987 syntax for file declaration.
But the simulation is succeed.
Can i know how can i remove the warning?
