Jul 16th, 2024, 12:00pm
Charge Pump with output voltage's limitation (Read 8206 times)
jjun2003
Apr 05th, 2006, 1:58am
Hi!
I am designing charge pump in PLL.
But, I don't know problem for designing charge pump.
I want to design charge pump that have a value of voltage limitation at output.
This is a source code.
module CP4 (vsrc, vref, siginc, sigdec, vout );
input   siginc, sigdec;
inout   vsrc, vref, vout;
electrical      vsrc, vref, siginc, sigdec, vout;
parameter       real iamp = 1m from [0:inf);
parameter       real vtrans = 1.25 from [0:inf);
parameter       integer cpmax = 5 from [0:inf);
integer inc_high;
integer dec_high;
integer selelec;        // selection flag of electrical(1:potential, 0:flow)
analog begin
//        @(initial_step) begin
//        V(vout, vref) <+ V(vsrc, vref)/2;
//        end
       inc_high = V(siginc) > vtrans;
       dec_high = V(sigdec) > vtrans;
       if (V(vout, vref) > cpmax )
               selelec = 1;
       else
               selelec = 0;
       @(cross(V(siginc) - vtrans, 1)) begin
               if (selelec)
                       V(vout, vref) <+ 2.5;
               else
                       I(vsrc, vout) <+ iamp;
       @(cross(V(sigdec) - vtrans, 1)) begin
               if (selelec)
               else
                       I(vref, vout) <+ -iamp;
This code is compiled but i can't simulated it for segentation fault.
Please, Help Me!!!! T T
Re: Charge Pump with output voltage's limitation
Reply #1 - Apr 5th, 2006, 11:37am
jjun2003 -
Your Verilog-A compiler should *NOT* have allowed this model.  You have contribution statements (<+) inside of an event (@), which is not allowed.  (The contributions are not "persistent" meaning that, for timepoints when a crossing is not detected, your model as written would have no contributions at all.)
You need to re-write your model so that a variable is set inside the event.
jjun2003
Reply #2 - Apr 5th, 2006, 8:48pm
Thanks for your advice.
I could have referenced charge pump cell in ahdlLib library.
But I don't know solution to this cell, too.
This cell use a analog function, thus only control state of current.
I want to know how to limit output voltage in this cell.
this is charge pump code in ahdlLib.
I modified to select branch in this code.
I(vsrc, vout)<+ iout_val; // Original Code
if (V(vout) < 2.5)
I(vsrc, vout) <+ iout_val;
else
V(vout) <+2.5; // Modified code
But i still can't simulate it for convergence.
I thought that modifed code generates abrupt chage.
But I can't change abstol in PLL.
I appreciate your help. Thanks.
// charge_pump
// -  Charge pump
// vout:            output terminal from which charge pumped/sucked [V,A]
// vsrc:            source terminal from which charge sourced/sunk  [V,A]
// siginc,sigdec:      Logic signal that control charge pump operation [V,A]
// INSTANCE parameters
//    iamp        = charging current magnitude [A]
//    vtrans      = voltages above this at input are considered high [V]
// MODEL parameters
//    {none}
// This model can source of sink a fixed current, 'iamp'. Its mode
// depends on the values of 'siginc' and 'sigdec';
//    When 'siginc' > 'vtrans', 'iamp' Amps are pumped from the output.
//    When 'sigdec' > 'vtrans', 'iamp' Amps are sucked into the output.
//    When both 'siginc' & 'sigdec' in same state - no current sucked/pumped.
module charge_pump(siginc, sigdec, vout, vsrc);
inout vout, vsrc;
electrical siginc, sigdec, vout, vsrc;
parameter real iamp=0.5m from [0:inf);
parameter real vtrans = 2.5;
  real iout_val;
  // Current multiplier - returns direction that charge should be pumped
  analog function real i_mult;
  input inc;
  input dec;
  input vtrans;
  real inc;
  real dec;
  real vtrans;
     integer inc_high;
     integer dec_high;
  begin
     inc_high = inc > vtrans;
     dec_high = dec > vtrans;
     i_mult = 0.0;
     if (inc_high == dec_high) begin
        i_mult = 0.0;
     end else if (inc_high) begin
        i_mult = 1.0;
     end else if (dec_high) begin
        i_mult = -1.0;
  endfunction
  analog begin
     @ ( initial_step ) begin
      iout_val = iamp*i_mult(V(siginc), V(sigdec), vtrans);
     @ (cross(V(siginc) - vtrans, 0)) begin
        iout_val = iamp*i_mult(V(siginc),V(sigdec),vtrans);
     @ (cross(V(sigdec) - vtrans, 0)) begin
Reply #3 - Apr 6th, 2006, 5:39am
I'd suggest trying a different approach for clamping the output voltage.  What you've got now switches formulation (I-source to V-source) and could be doing so during Newton iterations and hence completely disrupting convergence.
Suppose you set the output current
and then provide a shunt path to suck away the current if the output voltage is too high:
 if (V(vout) > 2.5)
   I(vout) <+ 1e6*(V(vout) - 2.5);
Try this in a simple test case before you attach it to a full circuit.  The 1e6 may need to be adjusted for your application.
Reply #4 - Apr 6th, 2006, 5:59am
jjun2003 wrote on Apr 5th, 2006, 8:48pm:
Are you sure you want the cross to detect transitions in both directions?  I would expect that "siginc" would go high to say "start charging up" and then "siginc" could go low but the pump would keep putting out positive current until "sigdec" triggers.  That is, I would make the second argument to cross a +1 to only detect positive-going transitions.
Reply #5 - Apr 6th, 2006, 6:31am
jjun -
Add the following lines to the module (after the I <+ transition... but before the "end" that closes "analog begin")
	if (V(vout) > V(vsrc)) begin
	    I(vout) <+ clamp * 1e6 * (V(vout) - V(vsrc));
	end else if (V(vout) < 0) begin
	    I(vout) <+ clamp * 1e6 * V(vout);
and then add
parameter integer clamp = 0 from [0:1];
after the other parameters.
Here's a netlist to try:
simulator lang = spectre
ahdl_include "charge_pump.va"
X1 (siginc sigdec vout    vsrc) charge_pump iamp=1m
X2 (siginc sigdec vout_cl vsrc) charge_pump iamp=1m clamp=1
V1 (vsrc 0) vsource dc=5
V3 (siginc 0) vsource type=pulse val0=0 val1=5 delay=10n rise=1n fall=1n width=5
n period=10n
V4 (sigdec 0) vsource type=pulse val0=0 val1=5 delay=15n rise=1n fall=1n width=5
n period=10n
R1 (vout 0) resistor r=10k
C1 (vout 0) capacitor c=1f
R2 (vout_cl 0) resistor r=10k
C2 (vout_cl 0) capacitor c=1f
tran1 tran stop=30n
Run it, and notice how "vout_cl" is clamped between 0 and 5, whereas "vout" hits +/- 10.
jjun2003
Reply #6 - Apr 6th, 2006, 7:50pm
BUT I can't work it for bus error.
If i add your codes before (I(vsr,vout)<+transition...) I can run simulation.
(BUT vout_cl is LOW(=), unconditionally)
May you give me a full code?
Following that modified code.
parameter integer clamp=1 from [0:1];
//      I(vsrc, vout) <+ transition(iout_val, tdel, trise, tfall);   // This causes bus error!!!
                 I(vout) <+ clamp*1e6*(V(vout)-V(vsrc));
           I(vout) <+ clamp*1e6*V(vout);
I always appreciate your help. ^^
Reply #7 - Apr 7th, 2006, 6:33am
Bus error?  Then you need to update your simulator.
It really shouldn't matter if you have the transition() call before or after my code.
