Aug 16th, 2024, 3:19pm
fstrobe for ADC testing (Read 2555 times)
nijMcnij
Apr 10th, 2006, 4:43am
hello all,
i have modelled a 10 bit charge redistribution SAR ADC in verilog A, the thing works fine.....but until now i have only been checking the output values using the waveform editor......i would like to use the fstrobe function to record the digital outputs to a file for later analysis.
but here is the catch, the digital outputs are either 3.3V (for a digital 1) or a 0 for a digital 0......how to do use the fstrobe function to record a value of 1 for a 3.3V and a 0 for a 0.....i tried the %B formating code but i get a compilation error "not supported yet"....i am using spectre
many thanks for your assistance
Re: fstrobe for ADC testing
Reply #1 - Apr 11th, 2006, 9:49pm
Well, at the point you're strobing, why not do something like:
integer digOut;
if (V(out)>1.7) digOut=1;
else digOut=0;
$fstrobe("...",digOut);
