Jul 18th, 2024, 7:30am
Please help me to build an FM Rx using TDA7000 (Read 1460 times)
ahmad_abdulghany
Apr 18th, 2006, 4:44pm
I am newbie to this forum,
I want you to help me to build a high bit rate Rx using TDA7000.. I could build the Rx as described in its datasheet, but it allow bit rate not higher than 9kbps   Cry
I want to increase its bit rate.. I think that reason of that low bit rate is due to that last low pass action made by last AF stage, Can I overcome this problem if i added in cascade another HPF with opposite c/cs to the latter LPF?
Is there any other modifications that i can made??
Please help me, I am in trouble!!!!
And any information will be appreciated..
You can find TDA7000 Datasheet here:
http://www.semiconductors.philips.com/acrobat/datasheets/TDA7000_CNV_2.pdf
Thanks alot in advance,
Ahmad,
