Sep 25th, 2026, 7:17pm
TT (Read 10077 times)
TT
TT
Apr 20th, 2006, 5:58am
I am trying to use pPar in a behavioral model. It works fine until I try to netlist. The netlister does no
pass the value of my CDF parameter but instead still writes pPar("myvalue"). I have checked the CDF options
and set the parAsNumber to yes ... but still nothing happens ?
Did somebody meet this problem before ?
TT
Re: TT
Reply #1 - Apr 20th, 2006, 1:17pm
Before you start DFII, enter:
setenv CDS_Netlisting_Mode Analog
if you're using csh/tcsh, or,
export CDS_Netlisting_Mode=Analog
if you're using ksh/bash, or,
if you're using sh as your shell.
This will then tell the spectre netlister to work in "Analog" mode, rather than "Digital" mode - there are two different parameter passing mechanisms (for historical reasons). You can also type:
setShellEnvVar("CDS_Netlisting_Mode=Analog")
cdsSetNetlistMode()
in the Command Interpreter Window (i.e. use the above SKILL functions) to achieve the same effect.
basf
Re: TT
Reply #2 - Mar 28th, 2007, 2:38am
Who knows how to make Cadence add scaling information in the netlist? Is there any variable to do that. I just want to automatically
add ".option scale=1e-06" string in generated netlist.
Re: TT
Reply #3 - Apr 12th, 2007, 12:46am
For spectre this is under the Simulation->Options->Analog. For the hspiceD interface, it's under Simulation->Analog Options->Model Analysis Options->General Options .
The corresponding cdsenv settings (to initialise these fields) can be done with the SKILL functions:
envSetVal("spectre.opts"  "scale" 'string  "1e-6")
envSetVal("hspiceD.opts"  "SCALE" 'string  "1e-6")
rajdeep
UK
Re: TT
Reply #4 - Dec 25th, 2007, 4:26am
Well, does it work for verilog behavioral models also??
I mean, is the meaning of pPar at all understood by the verilog netlister?
I'm using spectreVerilog and set the variable CDS_Netlisting_Mode to "Compatibility".
Rajdeep
