FastFurious
Hello Andrew, Thanks for replying. I get differen things when I ran assura from inside virtuoso or outside using avview. Inside virtuoso I select the rule file, but it complains about the assura_tech.lib that is non existent. Using avview, the error is saying that there are errors in assura_drc.rul file and it says can not open assura_drc_memory.rul (seemingly another file called within the assura_drc.rul) Can you please help. Thanks.
