ACWWong
Hi Prakash,
You can do a parametric anaylsis (the parameter to sweep is vtune).
As it is an oscillator, I guess a parametric pss anaylsis is what was done. The oscillation frequency, and oscillation amplitude are calculated in the pss run. If you use artist(ADE), you can set it up directly in the pss form under sweep OR you can just use the tools->parametric analysis form.
cheers
aw
