Jul 19th, 2024, 3:25am
Pages: 1 2
The definition of worst case speed model (Read 11037 times)
reactgary
May 08th, 2006, 2:38am
I am trying to simulate some circuit in cadence. The foundary (AMS) provided
some worst case speed model. So, what is the definition of worst case speed
model? Is it consider the effect of the worst case process parameter, is it included
the effect of mismatch?
Thank you
Gary
vivkr
Re: The definition of worst case speed model
Reply #1 - May 8th, 2006, 3:20am
Hi Gary,
Worst-case speed has nothing to do with mismatch. It typically implies high transistor VT, and low mobility.
Vivek
reactgary
Reply #2 - May 8th, 2006, 11:30am
Hi Vivek,
Thank you for your answer
Gary
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #3 - May 17th, 2006, 3:15am
vivkr wrote on May 8th, 2006, 3:20am:
Hi Gary,
Vivek
And high temperature as well
If you don't have time to do it good
you will find time to do it again
raf
Reply #4 - Jun 1st, 2006, 2:52pm
The temperature you have to set yourself. Probably to 120.
hamed
Athens, Greece
Reply #5 - Jun 2nd, 2006, 2:14am
* Referring to last comment about temperature:
The Vt of CMOS transistor decreases as temparature increases, So in worst case for speed, one has to combine lowest temperature with low speed corner (high Vt).
Hamed
always@smart
ASIA
Reply #6 - Jun 2nd, 2006, 5:14am
hamed wrote on Jun 2nd, 2006, 2:14am:
Hamed
Hamed,
I agree with you. Worst case supposed to be high Vth, Low mobility and at low temperature (-40). In this case, circuit usually produce lowest current, therefore lowest speed.
Smart
Smart
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #7 - Jun 3rd, 2006, 4:09am
I can't agree with that. The degradation of mobility with growing temperature is going much faster then reduction of Vt.
So, use SS process corner, the lowerst supply voltage and the highest possible junction temperature
Take ring oscillator of 7 invertors and check the frequency as a function of temperature in TRAN simulation and won't be surprized.
hamed
Athens, Greece
Reply #8 - Jun 5th, 2006, 4:30am
Hi mikki33,
Please check out the following:
"Analysis and Design of Analog Integrated Circuits"
Gray, Hursr, Lewis, Meyer - (Foth Edition)
page 47,48
Regarding your special example, there could be other reasons for.
Just to give you an idea, consider another similar example: with cascading few inverters you decrease the delay and increase the speed!!!
Hamed
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #9 - Jun 7th, 2006, 4:43am
Ok. I am designing CMOS analog during last 11 years, and according to my experience, high temperature increases delays. I just did the simulation, I suggested in my previous post. Ring oscillator, 7 inverters, 0.13 u process from very respectable FAB, model: BSIM3v3, supply 1.2V and 3 different TEMP 25, 70 and 125.
No parasitics, ideal supply.
The slowest corresponds to 125 deg C.
ACWWong
Oxford, UK
Reply #10 - Jun 7th, 2006, 5:21am
sorry to butt-into this conversation... i agree with mikki... slow speed for CMOS circuits is usually at high temperature... inspite of vth reduction...
fran2k5
Reply #11 - Jun 7th, 2006, 8:15am
Hello everybody,
I agree with mikki33 as well. Please note that the degradation of mobility depends on the movement of the crystalline lattice.
fran2k5
hamed
Athens, Greece
Reply #12 - Jun 14th, 2006, 6:23am
I think one has to be careful when defining "worst case" for analog or digital designs.
While in analog circuits, Vth is the most meaningful parameter which "Slow Cornet" is defined based on that, in digital circuits gds and capacitors  determine performance of the circuit in terms of the speed, and Vth is almost meaningless. That's why the "slow corner" gets worse if temperature decreases (Vth increases).
In addition there are some cases in which the interaction of devices behaviour changes the whole performance in a direction that may looks strange.
Hamed
vivkr
Reply #13 - Jun 19th, 2006, 6:00am
hamed wrote on Jun 14th, 2006, 6:23am:
Hamed
Hi Hamed,
I would be wary of making a statement like that. The most important parameter in analog design is arguably the transconductance (Gm) of the device. In fact, even in digital circuits, which are analog in reality, the same holds equally true.
And Gm depends first on mobility of the device (Kn'= un*Cox). Vth is a composite of several quantities, and ideally ought not to influence the speed. However, a larger Vth implies a higher overdrive to achieve the same Gm in the device. So both un and Vth are instrumental here.
The fundamental speed of the device is proportional to un/L, and hence shorter channels offer higher speed due to reduced transit time.
Please keep in mind the following:
1. Vth variation across process is strongly dependent on doping and oxide contamination as far as I know (Vth here implies threshold voltage).
2. If wafer A and B have the same un (mobility) & Cox & L but differ only in Vth, then the wafer with the larger Vth is the slower one. However, Vth alone cannot provide speed information.
3. Given a wafer, the speed will typically reduce with temperature despite the reduction in Vth at higher temperature. This is due to the fact that the mobility reduction due to higher temperatures has a stronger impact on speed than Vth reduction. Hence, the worst-speed situation is for worst-speed process (highest Vth, lowest Kn') and highest temperature with lowest supply.
4. Thus, the worst-speed corner assumes lowest un, highest Vth, and also longest L (in good process models).
5. Perhaps there are some special circuits which behave a bit differently, but in general the device transit time should increase as the temperature goes up, and this is the fundamental criteria for testing the speed of a device.
Vivek
hamed
Athens, Greece
Reply #14 - Jun 22nd, 2006, 1:42am
Hi Vivek,
Thanks for your comprehensive and useful note.
Hamed
Pages: 1 2
