Jul 19th, 2024, 1:15am
voltage conversion (Read 114 times)
grosser
voltage conversion
Jun 16th, 2006, 7:00am
hello
i need to convert 1.2V from bandgap  to 1.22V for comparator input. How can i do that? The solution can't take to much current. (max 10uA)
any ideas?
regards
TOM_KOR
화이팅 코리아
REP. South KOREA SEOUL
Re: voltage conversion
Reply #1 - Jun 20th, 2006, 8:04am
I thx , ouput stage bandgap add R(at upper BJT) or increse size of PMOS.
Huh
Under go~
vivkr
Reply #2 - Jun 21st, 2006, 5:59am
grosser wrote on Jun 16th, 2006, 7:00am:
hello
any ideas?
regards
Do you really need that 20 mV difference ? There are the following points to consider:
1. The variation of on-chip resistors in bandgaps gives approx. 50 mV variation in most cases across the process corners. Unless you are using a precisely trimmed bandgap, you may not gain much if you try to change the nominal value of your comparator reference to 1.22V.
2. Your comparator needs to have an offset appreciably lower than 20 mV.
May I ask why do you need such a precise comparator reference?
Vivek
