Quote:In your experience, is it possible to add signal to the SimVision waveform strip once the simulation is finished or are only the previously chosen signal saved
No not as far as I know.
But you can also use AMS out of the Analog Design Environment
if you use the most recent Cadence versions/updates
of NC-sim (IUS stream) and DFII (IC stream) optional MMSIM stream,
but don't ask me for exact version numbers.
Can you see 'ams' in your simulator choices in the Analog Design Environment?
Quote:I am happy to find a great expert on this field!
Thanks for the laurels, but I'm just started 2 month ago
to set up the AMS stuff for my company. That's why I
know most of the traps, because I'm steeped in already.
Bernd
