Jul 18th, 2024, 1:17am
Extranct coupled caps using xCalibre (Read 173 times)
May 15th, 2006, 10:54pm
Now MIM caps are replaced by the lateral flux caps more and more. So I draw a lateral flux cap made of Metal 2 ~ Metal 6. I need extract coupled caps using xCalibre. But the extracted netlist contains caps from both nodes to ground only. How do I extract coupled caps using xCalibre?
Best regards,
Yawei
bernd
Munich/Germany
Re: Extranct coupled caps using xCalibre
Reply #1 - May 16th, 2006, 1:03am
I haven't used Calibre as extraction tool for a long time,
but in the PEX GUI there is under 'Outputs' the
option 'Extract Type' which let you
define RCC == Distributed RC + coupling caps
Which must be the command line option
calibre -xrc -rcc
Oops I realized that my suggestions is for Calibre xRC
not xCalibre, for what you initially were asking.
I don't know if you can extract coupled Cs with xCalibre,
may be you have to upgrade.
Bernd
Just another lonesome cad guy
Re: Extract coupled caps using xCalibre
Reply #2 - May 16th, 2006, 7:28pm
Bernd,
I extracted the coupled caps successfully using your method. Thank you. But it is a netlist of distributed caps. I have to sum all distributed capacitances. Any method to extract a lumped C coupled between two nodes?
Yawei
bernd
Munich/Germany
Reply #3 - May 17th, 2006, 5:27am
I think it's only possible to have a distribute RC extraction or
a lumped C only extraction with Calibre, where lumped always is
decoupled.
But as I said it's a while since I worked with Calibre for
extraction.
If someone might know it better and I'm wrong please correct me.
Bernd
