pthoppay
What i meant by extracting the netlist is using the fucntion "create netlist" in the analog enviroment. Sorry for the confusion.
Yes, you are right I specified 0.18u and there is no value for "length" in the netlist and hence the simulator assumes the default length, but for any other value apart from 0.18 u it uses correct value. I have attached the netlist alongwith, from which it can be seen that in the MOSFET description there is no value for "L" and hence the simulator assumes the default value ( i read somewhere it is 1u). So my question is where and how should I change the default value, so that when there is no length specified in the netlist it takes as 0.18u and not any other value.
Thanks and Regards, Prakash.
