mikki33
![](https://designers-guide.org/forum/avatars/blank.gif)
Analog/Mixed Signal/High Speed
Israel
The third terminal is for P-Bulk connection. The NWell-resistor model takes in to account NWell-P-Bulk diode and parasitic capacitances to the P-Bulk as well.
I think you should have a very good reason to use NWell-resistor in your design (temperature sensor???). This resistor is very bad. It has very bad matching properties. It has very high parasitic capacitance. The sheet resistance variates +/- 40% with the process, it also variates 100% with temperature (0C-100C), it depends also on N-Well - P-Bulk voltage (non-linear), the profile of conductive layer is changing with the voltage across the length and it gives a good chance to get into the latch up (if 1 terminal of this resistor is connected to VSS).
I suggest to use non-salisided POLY resistor instead.
