Jul 17th, 2024, 11:38pm
package modeling? (Read 1047 times)
Faisal
package modeling?
May 11th, 2006, 8:48am
I have a switched capacitor design, for which I would like to evaluate different packages (comparing electrical characteristics). I looked at different package datasheets and they do not provide information such as bonding wire and/or trace inductance.
So lets say if I arbitarily choose CLDCC (Ceramic Leaded Chip Carrier), how can I obtain such information.. to model the package parsastics in my simulation
Paul
Switzerland
Re: package modeling?
Reply #1 - May 11th, 2006, 1:48pm
Hi Faisal,
try to get in touch with your packaging subcontractor. The parasitics not only depend on the package itself, but also on the type of bond wire they use (especially for the inductance). If your employer is an important customer you will of course get these informations much more easily Wink
Having a look at the datasheets of commercial products also helps to get an idea of what package is good for this or that application. The frequency of operation of your circuit should also help to find out whether you may be sensitive to package parasitics or not.
Paul
bernd
Munich/Germany
Reply #2 - May 12th, 2006, 1:19am
Just as a hint!
SpectreRF comes with a standalone package modeling tool called PKG.
It outputs a subcircuit of the modeled package which you can use for
simulation.
Type 'pkg' in your terminal and you will see it, assumed you have
a Spectre RF licenses.
Also documented in:
'Virtuoso SpectreRF Simulation Option User Guide',
Chapter 8 'Modeling RF IC Packages'.
I personally have no experience with this tool!
Bernd
Just another lonesome cad guy
Reply #3 - May 12th, 2006, 6:19pm
Faisal,
  First, it been a while since I have done this so my information
may be out out date. Bond wire inductance varies based on die
size and the bonding diagram so it would be difficult to include
this information in a generic package datasheet. For the same
reasons board trace parastics are specific to your board design
and the package manaufacturer can not know your board's
parasitics, a priori.
1) SpectreRF's packaging tool is useful but it does not support
   many package types.
2) The rule of thumb for hand calculating inductance is 1nH per
   mil of bond wire length for 1 mil diameter Au bond wire.
3) There are also tools for estimating the effect of board parasitics,
    such as, mtline and lmg.
4) Of course, if somebody is actually assembling the parts for you,
   then they can probably provide the parasitics[including bond wire    and package]  based on your pad locations.
schehrazi
University of CA, LA
Reply #4 - May 25th, 2006, 2:52pm
For the bond wire, you can assume that the inducatnce is about 1nH/mm lenght of the bond wire. It does not change that much with the diameter of it. This is good for both Aluminum and Gold bond wires.
For the package, the package manufacturers usually don't measure the electrical characteristics of it. You either have to measure it with a probe station or you should simulate it with an electromagnetic field solver. Usually leadless packages work fine up to 1GHz.
