Jul 18th, 2024, 3:31am
Why cant an OTA drive resistive loads..? (Read 3587 times)
sylak
Silicon valley
May 24th, 2006, 4:44pm
It is usually said that opamps are used for resistive loads and OTAs for capactive loads...
Why is that so...?
uncle_ezra
Re: Why cant an OTA drive resistive loads..?
Reply #1 - May 24th, 2006, 5:25pm
Well if OTAs were to drive resistive load its gain would depend on its output impedance in parallel with the resistive load. So a low resistive load would affect the gain, so usually you drive resistive load with a low impedance output.
schehrazi
University of CA, LA
Reply #2 - May 25th, 2006, 2:48pm
Another way to look at it: OTA is an Operational Transconductance Amplifier which means it converts voltage to current. Therefore, the output port is ideally a voltage controlled current source. Now, in a real circuit, there is some output impedance in parallel with that current source, the resistive part of which should be very big so that the DC gain is very large. We need this large output resistance so that the output port of the OTA can be approximated with an ideal current source. If you connect a small resistive load (compared to the output resistance) to an OTA, its DC gain drops. An OpAmp is basically an OTA followed by a driver stage, like a source follower, which reduces the output resistance and can drive small loads.
Raul
San Jose, CA.
Reply #3 - May 30th, 2006, 3:52pm
you can drive a resistor with an OTA, it's just that your open loop gain is going to be directly determined by the load resistor, avol=gmi/gload. if you don't care about this last thing them...
regards, Raul Perez
