Jul 18th, 2024, 7:31am
loop stability question (Read 3246 times)
RobertZ
the art of analog
San Diego, CA
May 26th, 2006, 10:14pm
I designed a fully differential OTA, and there is a negative feedback (resistor divider) from output to input.
There is also a CMFB inside this OTA.
In  CM sense, the first path(resistor divider) is postive, while the CMFB is negative feedback.
As I know, the first one should be weak, so that in overall, the system is stable.
When I checked the loop gain of the CMFB loop with the other feedback path (resistor divider) closed, I got a 0 degree phase at DC, which means a positve feedback?? If I break the resistor divider feedback path and check the CMFB loop gain, I got 180 degrees at DC.
but I also did transient simulation, eg, step vdd, the CMFB loop looks stable.
Is this circuit stable? or any concern?
Thanks!!
Robert
Re: loop stability question
Reply #1 - May 29th, 2006, 5:08am
Without considering the specifics of your circuit, spectre has a stability analysis (called "stb") which can be used to analyse both single-ended and differential loops - did you try using that? With the differential probe (called cmdmprobe or dmcmprobe, I forget), you can look at either the common mode or differential mode stability.
RobertZ
the art of analog
San Diego, CA
Reply #2 - May 30th, 2006, 7:20pm
I didn't know that analysis before. I will try that.
Thx!
Robert
raf
Reply #3 - Jun 1st, 2006, 2:41pm
I don't really understand your question, but the step response is directly related to your phase margin. So if your step response has no ringing you are fine.
