May 6th, 2024, 11:41pm
Time varying variable to laplace_nd() (Read 6037 times)
Tommy
Tokyo, Japan
May 31st, 2006, 2:17am
HI,
I know this is possible with Verilog-AMS.
My question is specific to Cadence Verilog-A in IC5.1.41
Here is a bit of code that fails in Cadence Verilog-A.
  analog begin
  @(initial_step("static")) begin
     nout[0] = V(in)*(R/(R+R_L));
     nout[1] = V(in)*(R/(R+R_L))*(R_C*C);
    dout[0] = 1;
    dout[1] = V(in)/R;
     dout[2] = L*C;
V(out) <+ laplace_nd(V(dr) , nout , dout);
When I pass a voltage (which is an input to the block) to laplace_nd using an array
the simulation fails. Is there a work around?
Tommy
Re: Time varying variable to laplace_nd()
Reply #1 - May 31st, 2006, 9:47am
According to the Verilog-AMS LRM (version 2.2), in Table 4-23, Section 4.4.15, the zeros and poles arguments to laplace_nd are supposed to be constant expressions. Thus, I am surprised that the simulator let you even compile the model.
The LRM is a little sloppy in 4.4.12.4 about a "vector of M real numbers"; I believe it is intended to be a concatenation like the example in 4.4.12.5:
V(out) <+ laplace_nd(V(in), {0,1}, {-1,0,1});
Tommy
Tokyo, Japan
Reply #2 - May 31st, 2006, 10:11pm
Geoffrey_Coram wrote on May 31st, 2006, 9:47am:
Mr. Coram,
Here is the exact bit of code that compiled in verilog-AMS
The coefficents are'nt in an array.
analog begin
     //numerator coefficients
     n0 = V(in)*(R/(R+R_L));
     n1 = V(in)*(R/(R+R_L))*(R_C*C);
     n0_2 = V(in)/R;
     n1_2 = V(in)*C;
     //denominator coefficients
     d1 = (C * (R_C + ((R*R_L)/(R+R_L)))) + (L/(R+R_L));
     d2 = L*C*((R+R_C)/(R+R_L));
     d1_2 = (L/R) + (C*R_C);
     d2_2 = L*C;
     if (analysis("static")) begin
        V(out) <+ V(in)*V(d);
     V(out) <+ laplace_nd(V(d), {n0, n1}, {1, d1, d2});
     I(outsense) <+ -1*laplace_nd(V(d), {n0_2, n1_2}, {1, d1_2, d2_2});
Reply #3 - Jun 1st, 2006, 4:10am
Tommy wrote on May 31st, 2006, 10:11pm:
"verilog-AMS" is a language, not a simulator.  What *simulator* were you using?
But the LRM says what it says; I would argue that that simulator has a bug if it allows the coefficients to be voltage-dependent, and you can't rely on it.  What happens if you connect some feedback, such that V(in) depends on V(out)?  Convergence in an analog simulator could be completely messed up.
That said, it looks to me that you could simply factor out V(in) from the numerator coefficients.  I assume that R, C, R_L, and R_C are all parameters?  In that case, I'd suggest making the coefficients parameters (localparams if your simulator supports them, which prevents someone from overriding them):
parameter real R = 50;
parameter real L = 10n;
parameter real C = 1p;
parameter real R_L = 50;
parameter real R_C = 50;
parameter real n0 = R / (R+R_L);
parameter real n1 = (R/(R+R_L))*(R_C*C);
parameter real d1 = (C * (R_C + ((R*R_L)/(R+R_L)))) + (L/(R+R_L));
parameter real d2 = L*C*((R+R_C)/(R+R_L));
and then you can write
 V(out) <+ laplace_nd(V(d)* V(in), {n0, n1}, {1, d1, d2});
Tommy
Tokyo, Japan
Reply #4 - Jun 1st, 2006, 9:31pm
Mr. Coram,
I used silvaco smartspice which  refers to Accellera Verilog-AMS std .
Yes factoring out V(in) in this case works. But I was looking at a case
where I cannot factor out the term.
Tom
Reply #5 - Jun 2nd, 2006, 4:17am
Do the filter coefficients really depend on the input voltage as a function of time?
