May 19th, 2024, 7:29am
problem with $realtime ??? (Read 8858 times)
rajdeep
UK
May 31st, 2006, 5:04am
Hi all, I am trying to model a sawtooth generator using verilog-A (not AMS, so I cannot use idtmod). The code looks like :
@(timer(0,period)) begin
offset = $realtime;
slope= 5e7;
V(ramp_out) <+ slope*($realtime -  offset);
This works fine for a simulation time less than 10us. But once  I set the simulation time somewhat higher than that, the output just goes bizzare!!! Number of triangles in the o/p starts to get flattened out .
I'm not sure why it is happenning??? Does $realtime have anything to do with the simulation time???
Plz help
Rajdeep
rajdeep
UK
Re: problem with $realtime ???
Reply #1 - May 31st, 2006, 5:24am
Sorry folks!!! I got the solution. I have to increase the timestep of the simulation to the order of ns ,
But still can anybody suggest a way to circumvent this type of problem, where the inaccuracy is due to timestep of the simulation.
I forgot to mention , the period used in the code is 0.5us.....that's why probably a  1us simulation time step was not enough.
Rajdeep
bernd
Munich/Germany
Reply #2 - May 31st, 2006, 6:11am
I assume you have set errpreset to liberal,
with modifies the parameter reltol and sets the
integration method to 'gear2' which damps the
signal.
Try with errpreset == moderate
Bernd
Just another lonesome cad guy
rajdeep
UK
Reply #3 - May 31st, 2006, 6:16am
It didn't even worked with conservative  :-/..
bernd
Munich/Germany
Reply #4 - May 31st, 2006, 6:26am
Why do you set the time step at all?
Spectre in general computes the best time step internally.
Bernd
Reply #5 - May 31st, 2006, 7:19am
It seems to me that you should be using $abstime rather than $realtime. Also, idtmod() should be available in Verilog-A.
rajdeep
UK
Reply #6 - May 31st, 2006, 7:22am
Otherwise, it was not working. I don't think it can actually choose a good timestep by itself. Maybe it fails to do so n case of verilogA models.
A timestep of 10nS is giving fine result Cool
rajdeep
UK
Reply #7 - May 31st, 2006, 7:28am
Is it the same Ken Kundert who wrote the book on Verilog-AMS???/
I have tried with abstime..didnot change. Infact, it gives a warning to change $realtime with $abstime!!!
Don't know!! I cudnot find idtmod in the whole Verilog-A LRM...i shud have tried though.
Rajdeep
Jess Chen
California Bay Area
Reply #8 - May 31st, 2006, 8:27am
You could also try $bound_step. I am not sure I have the syntax correct but this VerilogA command limits the size of the time steps. You can use this command to link the maximum step size to a frequency or slope defined elsewhere in the code.
As a side note: if you are resetting your integral when some event occurs, you may want to use a @cross statement to make sure the reset occurs with the desired time resolution.
-Jess
Reply #9 - May 31st, 2006, 9:11am
Rather than @cross, you might want to investigate the optional 3rd argument -- timetol -- for the timer event.
Reply #10 - May 31st, 2006, 9:27am
rajdeep wrote on May 31st, 2006, 7:28am:
1) Yes, it's the same Ken.
2) The simulator I'm using says that $abstime should be used instead of $realtime.
3) idtmod is in 4.4.6 of the Verilog-AMS LRM 2.2 (and the same section in 2.1), titled "Circular integrator operator"
rajdeep
UK
Reply #11 - May 31st, 2006, 12:59pm
Thanks a lot folks!! I will try all the options. Infact, was thinking of timetol option before leaving for home.
The cross option will make the code somewhat clumsy I guess...but then if it works fine.
Rajdeep
