Material,
If you using Spectre and analyzing non-sampled circuits, op-amps, etc., then use the Fourier component. If you are simulating a Nyquist ADC/DAC /SH use the rectangular function. If you are simulating an Over-sampled ADC/DAC, then use the Hann window function. The details of the simulation setup for Nyquist and Over-sampled cases have been discussed in previous appends.
