Eugene
Sorry I did not respond sooner. I was out of the office. I tried your code and did not see the problem; I saw the correct output noise. The only difference is that in my "test2" module, I have
input in; output out; electrical in, out;
i.e. you may need to insert the "input..." and "output..." lines. Also, the coefficients are the coefficients of z-1, so you had it right the first time.
