Aug 18th, 2024, 5:28am
Pages: 1 2
frequency function in frequency domain (Read 17339 times)
Eugene
Re: frequency function in frequency domain
Reply #15 - Jun 15th, 2006, 1:43pm
Sorry I did not respond sooner.  I was out of the office. I tried your code and did not see the problem; I saw the correct output noise. The only difference is that in my "test2" module, I have
input in;
output out;
electrical in, out;
i.e. you may need to insert the "input..."  and "output..." lines. Also, the coefficients are the coefficients of z-1, so you had it right the first time.
icdesign
Reply #16 - Jun 15th, 2006, 5:29pm
Thanks Eugene,
It's working now.  I really appreciate that you hold my hand up to this point.
Thanks again.
Pages: 1 2
