Jul 3rd, 2025, 2:39am
veriloga model for esd pads (Read 2385 times)
mengm0411
Jun 07th, 2006, 5:02am
I'm trying to establish veriloga model for ESD pads based on their TLP data, where Current is a multi-valued function of voltage for some current range, i.e, there is negative differential resistance (voltage decreases when current increases) or snapback region, as shown in the attached figure. This nature is easily leading to convergence problem: I got "timestep too small" and the simulation terminated. Can anyone give me a hint in how to effectively model this ESD behaviour? Thanks.
Jess Chen
California Bay Area
Re: veriloga model for esd pads
Reply #1 - Jun 7th, 2006, 8:26am
Yikes! Your IV curve looks like a modeling nightmare. However, have you tried turning the curve on its side? i.e. have you tried modeling it as a current controlled voltage, v(i), instead of a voltage controlled current source, i(v)?
-Jess
Reply #2 - Jun 7th, 2006, 1:01pm
You might want to have a look at:
"Compact Modeling of On-Chip ESD Protection Devices Using Verilog-A"
[ J. Li, S. Joshi, R. Barnes, and E. Rosenbaum ]
http://ieeexplore.ieee.org/iel5/43/34175/01629139.pdf?isnumber=34175&arnumber=16...
I have a philosophical objection to the use of the analysis() function to introduce a different set of equations for ac analysis, but it's at least something published to start from.
I'll also note that the TLP data is *not* a dc i/v curve.  TLP applies pulses of increasing voltage, then measures the I and V at some fixed time after the pulse is applied.  You'll want to understand that and make sure your circuit simulation is set up to mimic it.
NKS
Seoul, Korea
Reply #3 - May 25th, 2007, 4:52am
Hmmm... Huh your comment below about "a philosophical objection to the use of the analysis() function ..." seems to suggest that the authors have made public their Verilog-A source code, somewhere. Am I correct about this? If so, could you tell me where I can get a copy? Thanks in advance.
Geoffrey_Coram wrote on Jun 7th, 2006, 1:01pm:
Reply #4 - May 25th, 2007, 8:38am
As I recall, the outline of the V-A model is available in the paper I cited, or another by one of the authors.  The full model, though, is not available (except maybe to SRC members?).
NKS
Seoul, Korea
Reply #5 - May 28th, 2007, 4:40pm
Geoffrey,
Thank you for the info.
Cool
NKS
Seoul, Korea
Reply #6 - Jun 12th, 2007, 11:03pm
Does anyone know how stable the model described in the paper is? I've been coding a Verilog-a code based on the outline described in the paper for some time, now. So far, I have been able to make it exhibit the snapback phenomenon for ggNMOS (Vgs=0) case as shown in the figure below. However, I was only able to get to this point per lots of parameter tweaking. Without tweaking, a simulation run generally ends up in convergence error as shown in the same figure for Vgs=0.5V case.
Upon reading the paper, I got the impression that the equations shown in the paper do not induce severe convergence problems. What common mistakes would I be making?
Specifically I have following questions:
1. What are the values for the parameters that would result in reasonably similar results as the plots shown in the paper; I've tried to contact one of the authors about
this matter but did not receive any response. For example, p1, p2, p3, A, B, I_oc, Iob, R_sub, R_on, C_GD, C_Db, C_GS, C_Sb, C_Gb, Tox, Mu_eff.
2. Do I need to check some condition(ex. voltages across some nodes) before executing the equations in Table II?
3. How good (low convergence error occurence and reasonable precision) is this approach of behavior modeling ESD devices? Is the difficulty with simulation convergence
inevitable with this kind of approach? Or am I missing some subtilties with my coding.
Thanks in advance.
NKS  :(
