Jul 22nd, 2024, 10:29am
AMSDesigner's speed (Read 4604 times)
Cri Azzolini
University of Parma, Italy
AMSDesigner's speed
Jun 15th, 2006, 8:08am
I recently perfomed mixed-mode simulation of a design containing both analog (schematic) and digital (verilog) section with AMS-Designer. I noted that the same transient simulation performed on a schematic containing only the analog section of the design takes more time with Spectre: the difference is huge, about 50% or maybe more!
The simulation is run on the same workstation and the simulation queue was empty in both cases.
I cannot explain how this may happen: I mean, as far as I know, AMSDesigner uses Spectre for the simulation of the analog part of the circuit!
Any ideas?
Cri
View Profile WWW cri.azzolini   IP Logged
Re: AMSDesigner's speed
Reply #1 - Jun 16th, 2006, 5:05am
Does the digital block control the analog, and if so, how did you replace it in the analog-only simulation?
Cri Azzolini
Reply #2 - Jun 16th, 2006, 5:24am
Hi Geoffrey,
the analog block drives a digital post-processing digital machine. Actually there is some feedback signal from the digital block to the analog core. Does it make difference?
In the analog-only simulation I simply delete the digital block and no post-processing is done: in this way the output analog data are raw and not corrected by the digital machine.
Thanks, bye!
Cri
Reply #3 - Jun 19th, 2006, 5:52am
I haven't used AMSDesigner, so I don't know if it runs Spectre in a low-accuracy mode or something ... What does the feedback do?  In the analog-only simulation, if this signal is fixed at a "bad" bias point (I'm assuming it's not completely missing), then you could be balancing the analog circuitry at a sharp nonlinearity that could be causing convergence problems in the analog solver.  But that's pure conjecture.
Cri Azzolini
Reply #4 - Jun 20th, 2006, 12:00am
Yes, I understand what you suppose about the "bad" bias point: it could be a possible reason. I am going to verify!
Thanks for your kind reply and regards,
Cri
