Sep 1st, 2024, 8:21am
cryogenic operation of semiconductor devices (Read 2090 times)
vivkr
Jun 21st, 2006, 6:36am
I am just curious as to how Si chips are able to work down to very low temperatures (5K as used in IBM's experimental 500 GHz processor). Is there no "freezeout temperature" below which the available thermal energy is insufficient to free enough carriers from the donor and acceptor levels?
Vivek
Croaker
Re: cryogenic operation of semiconductor devices
Reply #1 - Jun 21st, 2006, 10:57am
That's a good question.  I guess I could check the textbooks, but I seem to  recall that it wouldn't take too much energy to put donor electrons into the conduction band.  Although, the number of intrinsic carrier pairs from thermal generation would be quite low.
