Jul 19th, 2024, 7:19pm
question about biasing current (Read 3799 times)
mosman
china
Jun 27th, 2006, 12:38am
hi dear all:
i have been questioned about the biasing current:
(1) Why do we use those biasing current which vary with temp?
i find the biasing current of many many circuits come from the BGP circuit, so its amplitude must change with temperature. i think if we use the constant current the performance of circuit may be better than those using varying circuit.(just guess)
(2) Can i use the un-changing current to bias every circuit?
many thanks!!
hope you can help me!
View Profile mosman   IP Logged
raf
Re: question about biasing current
Reply #1 - Jun 27th, 2006, 5:56am
There are many uses. For example: Varying current tracking a varying resistor will give you a constant voltage over PVT.
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #2 - Jun 27th, 2006, 7:32am
You may use PTAT current in amplifiers partially compensate for the band width reduction.
And, yes, you may use constant current to bias particulary any circuit...
If you don't have time to do it good
you will find time to do it again
mosman
china
Reply #3 - Jun 27th, 2006, 5:17pm
raf wrote on Jun 27th, 2006, 5:56am:
this is a good idea. thanks! by the way, i know PTAT current is used in bipolar circuit to hold the gm constant. but in cmos circuit(i.e., cmos amplifier), what advantage is using PTAT current?
mosman
china
Reply #4 - Jun 27th, 2006, 5:27pm
mikki33 wrote on Jun 27th, 2006, 7:32am:
thanks! Mikki, like the above reply, i know PTAT current is used in bipolar circuit to hold the gm constant. but in cmos circuit(i.e., cmos amplifier), what advantage is using PTAT current? and could you explain the reason for band width reduction in detail. why do many CMOS circuits (i.e., amp, comp, OTA,...) still use PTAT current? i plan to use constant current in my circuit. but i am afraid there may be some reason for using PTAT i have not known. so i want to ask for your help.
mikki33
Analog/Mixed
Signal/High Speed
Israel
Reply #5 - Jun 30th, 2006, 12:30am
Band width is gm/Cload.
gm is sqrt(2*μn*Cox*(W/L)*Id)
With temperature μn is reduced, so increase of Id is compensating for gm reduction and gm/Cload
