Jul 22nd, 2024, 12:25am
help on repeating simple t/h example in SpectreRF (Read 4628 times)
LL
California
Jun 28th, 2006, 12:31am
Hi -
I'm new to spectreRF and find the article "Simulating Switched-Capacitor Filters with SpectreRF" (under Anaysis/Analog SImulation) extremely informative. However, I'm having a difficult time repeating the figures for just a simple t/h simulation. If you were able  to repeat that successfuly, I would be very much interested to know how you did it.  Perhaps, Ken can also provide some hints on how you generated those plots for the article.
thanks,
LL
Re: help on repeating simple t/h example in Spectr
Reply #1 - Jul 20th, 2006, 9:36am
Perhaps you can be more specific? For example, which figures are you trying to recreate?
Have you tried downloading the netlists and starting from there?
LL
California
Reply #2 - Jul 26th, 2006, 11:05pm
Hi Ken,
Thank yuo for your reply.  Yes I did download the netlist but still wasn't able to repeat the plots in the doc. BTW, the netlist as is doesn't run. I  made some mod before I was able to get the sim to run.
I see that dwingram is asking the same thing I after.  Your reply to his post will defintely clear up my inquiry as well.
I will wait for your reply.  Many thanks in advance.
Reply #3 - Jul 27th, 2006, 10:05pm
Really? Did you supply the -E argument to spectre (it gives you an error if you don't, since this example uses cpp directives).
I just re-tried both netlists, and can run with:
spectre -E tah.ckt
spectre -E scf.ckt
LL
California
Reply #4 - Jul 27th, 2006, 11:54pm
HI Andrew,
Thank you for your reply.  Yes, the -E corrected the error.  Does your pxf result look close to fig 8 in the doc?
Reply #5 - Jul 28th, 2006, 4:48pm
There was an error in the paper. To get the results shown in Fig 8, the PXF analysis must use the node 'sout' rather than the node 'out'. I have updated the paper and the netlists.
LL
California
Reply #6 - Jul 29th, 2006, 10:32am
Thank you very much Ken (and Andrew as well) for your help.
